mechsmurf 0 Posted May 8, 2008 is there supposed to be anything inbetween the top cover on the suspension strut and the chassis ie a rubber Share this post Link to post Share on other sites
chris1986 1 Posted May 8, 2008 there is like a round rubber ring yes. then under that is the bearing Share this post Link to post Share on other sites
mechsmurf 0 Posted May 8, 2008 are these the rubbers that you can get off ebay or where could i get replacements many thanks Share this post Link to post Share on other sites
cybernck 403 1 Cars Posted May 8, 2008 http://www.bakerbm.com Share this post Link to post Share on other sites
Rich_p 23 Posted May 23, 2008 Can these be replaced just by undoing the 3 top mounting bolts and dropping the shock once the car is jacked up or is it a shock off the car job? Share this post Link to post Share on other sites
KRISKARRERA 2 1 Cars Posted May 23, 2008 But there isn't anything between the top of the strut and the bodywork. Share this post Link to post Share on other sites
Rich_p 23 Posted May 23, 2008 (edited) But there isn't anything between the top of the strut and the bodywork. I haven't taken a 205/309 apart yet so wouldn't know! I'm assuming it's shocks off then? Edited May 23, 2008 by Rich_p Share this post Link to post Share on other sites
KRISKARRERA 2 1 Cars Posted May 23, 2008 I assume you were asking if there is anything between the bodywork and that top bit that is visible now? Share this post Link to post Share on other sites
GLPoomobile 958 Posted May 23, 2008 That's what I assumed too Kris. The metal top plate that protrudes through the strut turret has nothing between it and the shell. The bush mentioned above goes between the metal top plate and the rest of the top mount assembly. Share this post Link to post Share on other sites
