milk_churn 0 Posted May 8, 2008 Paul AKA '205Turbo' told me how to check whether the TPS switch is working or not, as i mentioned to him that on the two times i took my car for a run it felt like it didnt want to go past 4000rpm. So i checked it earlier and there's no click from the switch through the whole range of the throttle opening and closing. What effect would this be having on my car? Has anybody got a spare switch in their collection of parts that they wouldnt mind selling for cheap as i'm skint beyond belief, after buying a rear beam, a bootlid and a bonnet this week. Share this post Link to post Share on other sites
welshpug 1,666 Posted May 8, 2008 have you tried adjusting the switch? Share this post Link to post Share on other sites
KRISKARRERA 2 1 Cars Posted May 8, 2008 The only click you should hear is as the throttle is opened from idle. You need to get a multimeter on it to see if it's doing it's wide open throttle gubbins correctly. Share this post Link to post Share on other sites
Miles 331 1 Cars Posted May 8, 2008 It won;t effect the running at all really, It's a simple switch on these to tell the ECU is the throttle is wide open or shut, you can try unpluging it to see what happens Share this post Link to post Share on other sites
milk_churn 0 Posted May 9, 2008 have you tried adjusting the switch? adjusting it? no i havent tried anything yet, just told that if it isn't making a click noise it should be. How do i adjust it? Share this post Link to post Share on other sites
Rob_the_Sparky 10 Posted May 9, 2008 I'd agree with Miles. To adjust it check Haynes, basically the idle switch should engage just as the throttle closes. If it doesn't then likely it has been adjusted not to as it is a bodge to try and fix a poor idle (note, a bodge not a fix). Listening for a click is not a decent test though, you need a meter to check it works it may click and still not work. Rob Share this post Link to post Share on other sites
