saveloy 8 Posted May 7, 2008 For a couple of months now the car has been a pig to start. I thought it was the change in weather, i.e: warmer, but I'm not convinced that is the case anymore. It happened suddenly - an ambient temperature of approximately 1 degree Celcius and the car started on the button. Now that it is about 20 degrees, it's an absolute pig. But the ECU map has not changed and the car always started very well. It's the suddenness of the problem that has me baffled. My only thought is grubby injectors. Share this post Link to post Share on other sites
welshpug 1,682 Posted May 7, 2008 coolant temp sensor? whip a plug out and see if its wet/black. Share this post Link to post Share on other sites
saveloy 8 Posted May 7, 2008 First thing I thought of. They were all fine, but I put in a new set of plugs anyway. This issue arose the day after the starter solenoid spade connector dropped off. I can't think of any link between the two though. Share this post Link to post Share on other sites
Super Josh 4 Posted May 7, 2008 It's cos it knows you want to get rid of it, poor thing Josh Share this post Link to post Share on other sites
boldy205 75 Posted May 7, 2008 its sparking and fueling i suppose? What engine is it? Share this post Link to post Share on other sites
saveloy 8 Posted May 9, 2008 8 valve TT, running Omex management. It's certainly a lack of fuel, since it will jump into life if I crank it over with the loud pedal on the floor. Share this post Link to post Share on other sites
