Garry
GTI 6 Supercharged Won't Fire Up!
smighall
So has it started now then?
DOH!
crossie
Just been on the phone to garry and he is driving up home.
He is going to try the fuel rail on the other direction.
But it will be tomorrow morning before he does it!
m@robson
the suspense is killing me :)
TT205
Me too :)
crossie
running!
Just spoke to him
Garry needs a couple of items and to fit the exhaust but it started!
Should have taken it out around lunch time!
Edited by crossie
Super Josh
:D How chuffed must he be feeling now :)
Josh
DrSarty
Well done G. And thanks for the PM; made my day. It proves my memory isn't quite useless yet eh?
Now pull your finger out and post some vid, with sound and tell us how she goes!
DrS :)
Alastairh
205Gtidrivers meet at yours for passenger rides? :D
Mines a tea, 2 sugars :)
rich_gti6
Glad it was something so simple - and glad it's not my ECU reprogramming skills at fault!
Looking forward to seeing how this goes - this conversion is quick enough in a 1300KG 306, let alone a stripped 205.
Garry - a couple of things to check before you road test it:
1. It's of utmost importance your running decent engine oil - a motorsport 10W50 would be my recommendation. You want something with top-end protection and film stength - hence the 10W50.
2. Make sure the Rotrex is primed properly, and has oil flow through it. Disconnect the return banjo on the traction fluid reservoir and physically check to see you have flow before going anywhere.
3. Make sure cooling system and fans etc Are all working as they should. Heat will be more of a problem with the FMIC in front of the rad.
4. The 'charger has a 100 k/m [65 mile] running in period. It should be ok to give it some beans before this - just make sure it's all warmed up etc.
5. Make sure your on superunleaded fuel and have the cooler grade plugs in.
Happy days :)
m@robson
Im so relieved its not something i did :) i was having 2nd thoughts about all the sensors i extended.
