dommorton
Fitting Weber 45's
dommorton
I'll be embarking on the fitting of Weber 45's to my 1991 1.9 8 Valve tomorrow.
Having taken a quick squint at the car and reading a few threads and How To's etc I'm still left with a few questions.
What can I do with the coil? :D it's the later type that sits on top of the inlet manifold.
Is it usual to keep it and just re-home it somewhere else in the engine bay? if so does anyone have a suggestion of a good home and way of mounting.
Or would it be a better bet to switch to an older wet coil? If so does the wiring need to be changed? :D
The other question is what to do with all the breathers? do I leave most of them be and just vent the main one from the filler cap off to a bottle?
I've also read the engine mount metal work will need some cutting to clear the manifold. Is this the case with an 8v too?
I see the general consensus is to remove the pipe for the vac advance on the dizzy. Is this a good idea? do I need to alter the timing at all to compensate?
All answers and any other tips gratefully received :D
Edited by dommorton
suth82
Hi, i'll try to answer your questions as best as possible but my carbs are on an mi16 so some things may be different.
What can I do with the coil? it's the later type that sits on top of the inlet manifold.
I had to change to the old type coil and make up its own wiring loom between the ignition amp and dizzy, this is pretty simple and a diagram can be found on here.
I would recomend a catch tank and route all the breathers into it, this prevents any of the muck being pulled back into the engine.
I did have to cut a bit out of the Mi16 mount but dont know if you will have to on the 8v.
Remove the pipe and blank it, the best answer is to install a dizzy with a modified advance curve.
Paul
Edited by suth82
dommorton
Nice one thanks Paul.
I mostly fitted them today, and got it running on the standard coil. I'm guessing so long as I can mount it somewhere it'll be fine??
Rom
Yeah chuck the coil anywhere :ph34r: Aslong as its mounted somewhere and not dangling !
Mines over where the 8v coil normally goes. As i didnt have the bracket to mount it to my inlet. Ill get one oneday :)
dommorton
Nice one thanks
