allanallen 528 2 Cars Posted May 2, 2008 hi all, just after a bit of help checking that the stuff ive got to use with my e48 is correct and what else i'll need, right heres what ive got and where they're from; air temp sensor, rover k series (green in colour) water temp sensor, 1.9 mi16 coil pack,vauxhall 2.0 16v ecotech throtlle pos sensor, volvo (magnetti marelli) tdc sensor, peugeot i still need a map sensor, does anyone have any suggestions where to get a suitable one. the car will be running 0.5bar of boost max. Also does it matter where i position the air temp sensor and the map sensor on the manifold? sorry for the simpleton questions , cheers al Share this post Link to post Share on other sites
Sandy 191 Posted May 2, 2008 hi all, just after a bit of help checking that the stuff ive got to use with my e48 is correct and what else i'll need, right heres what ive got and where they're from; air temp sensor, rover k series (green in colour) water temp sensor, 1.9 mi16 coil pack,vauxhall 2.0 16v ecotech throtlle pos sensor, volvo (magnetti marelli) tdc sensor, peugeot i still need a map sensor, does anyone have any suggestions where to get a suitable one. the car will be running 0.5bar of boost max. Also does it matter where i position the air temp sensor and the map sensor on the manifold? sorry for the simpleton questions , cheers al Most multipoint S1 106s have a 100KPa (1 bar) MAP sensors on a separate pipe. Should be ideal. Share this post Link to post Share on other sites
allanallen 528 2 Cars Posted May 2, 2008 Most multipoint S1 106s have a 100KPa (1 bar) MAP sensors on a separate pipe. Should be ideal. ahh, Ive got a scrap 106 xsi at home so that should be easy. forgot to mention i have a lambda from a zetec mondeo (4 wire) Sandy, do you know if all my other stuff is compatable? cheers al Share this post Link to post Share on other sites
Super Josh 4 Posted May 2, 2008 i still need a map sensor, does anyone have any suggestions where to get a suitable one. the car will be running 0.5bar of boost max. Most multipoint S1 106s have a 100KPa (1 bar) MAP sensors on a separate pipe. Should be ideal. Surely if you are running 0.5 Bar of boost, you're going to need at least a 1.5 Bar MAP sensor? Josh Share this post Link to post Share on other sites
welshpug 1,675 Posted May 2, 2008 Surely if you are running 0.5 Bar of boost, you're going to need at least a 1.5 Bar MAP sensor?Josh no, as an N/A engine is always running negative pressure, with boost it'll be positive. Share this post Link to post Share on other sites
Mad Professor 7 Posted May 3, 2008 (edited) From how I understand map sensors is that 100kpa = 1bar = 1 Atmosphere. So 0kpa is a perfect Vacuum, <100kpa is a Vacuum, 100kpa is Atmosphere, and >100kpa is possitive pressure. 100kpa is the reading at sea level, and can move from 95kpa to 105kpa depending on the weather. Most N/A cars that I have worked on with MAP sensors, are norm 100kpa, 105kpa, 110kpa. Edited May 3, 2008 by Mad Professor Share this post Link to post Share on other sites
pee vee 1 Posted May 4, 2008 yes you will need at least a 1.5bar map sensor as i understand (1 bar is atmospheric pressure, and then the 0.5 bar you want to run on top of that) only one i could say is standard sierra cosworth have 2 bar map sensor, esc cos has 2.5. they are webber marelli ones. so are good quality. they are cheap and easy to get. Share this post Link to post Share on other sites
Super Josh 4 Posted May 4, 2008 no, as an N/A engine is always running negative pressure, with boost it'll be positive. My understanding is that a 1 Bar MAP sensor will only read atmospheric pressure. So to measure a boosted (positive pressure above atmospheric) application, 0.5 Bar in this case, you need to add that to the equation. So I still stand by my original statement that you'll need at least a 1.5 Bar MAP sensor in this application. Josh Share this post Link to post Share on other sites
cybernck 403 1 Cars Posted May 4, 2008 ^ that's correct. Share this post Link to post Share on other sites
allanallen 528 2 Cars Posted June 6, 2008 right oh, I've managed to get a cosworth 3 bar map sensor but i now need a suitable plug for it. So does anyone know where i can get a suitable connector/plug from? Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted June 11, 2008 So does anyone know where i can get a suitable connector/plug from? Simtekuk.co.uk (forum discount ) or Vehicle wiring products. Graham. Share this post Link to post Share on other sites
allanallen 528 2 Cars Posted June 12, 2008 Simtekuk.co.uk (forum discount ) or Vehicle wiring products. Graham. cheers graham, not sure exactly which connector it is on the simtek website but i'll give them a ring tommorow and hopefully they can sort me out. Share this post Link to post Share on other sites
