gerlewislewis
Spare Cable From Coil?
gerlewislewis
there is a very short white cable (3inches) with a female connection - similar to an earth - hanging out the back of the coil, should this be connected anywhere? I cant see anywhere it should go.
pee vee
should it go to the surpressor? (little black box with a single wire coming from it)
gerlewislewis
where is the surpressor? - the cable is only very short and I cant see anything with a spade on it!
DirtyFlare
it doesn't connect up to anything, good old Peugeot :(
gerlewislewis
bugger I was hoping that was my ignition problem!
steve@cornwall
That's what I thought 'till I bought a carb'ed auto - it connects to part of the auto choke mechanism :(
KRISKARRERA
The suppressor! It's usually bolted onto the inlet with the same bolt that holds the coil on. Mine snapped off. Haven't noticed any difference though.
No supressor's on the 8v's Kris, Whats up with the ignition?
Ignition wiring diagram for 91 on (i.e coil on inlet) show a suppressor.
Edited by welshpug
gerlewislewis
do you ave one on yours Meirion?
spare wire yes, suppressor no!
