bea5ty
Caliper Bleed Nipple
bea5ty
Just fitted new disks and pads to our hilclimb car and when beading the brakes I managed to snap the nipple off a rear caliper. The good thing is that the nipple is screwed into a bolt which I have removed. Are replacement bolts available from Peugeot or will I require a new caliper?
Edited by bea5ty
The bolt part you refer to is usually fitted by the reconditioning companies to reclaim u/s calipers, standard Peugeot ones don't have this.
As you've got the bolt out I'd get it in a vice and drill out the bust bit.
bea5ty
Thanks that saves a trip to the parts department tomoro then, sods law says ive snapped the tap I need!
