thrasher
Mi 16 Clutch Plate Into 1.9 Xu
thrasher
as above,will a mi 16 clutch plate fit a 1.9 xu engine,cheers gus
If you use an Mi16 flywheel, yes. On the 8v standard flywheel, no.
only if you fit a 215mm Mi16 or GTi6 flywheel.
thrasher
cheers ,thought it might fit,but obviously not.
