Pob 1 Posted April 25, 2008 Hi all, A while back a posted a question on the forum about a problem with my clutch after the clutch cable snapped. I'm still at a loss with this, I've removed the gearbox, replaced the clutch fork, re-fitted the gearbox and its still very very stiff... so much so you can see the brake and accelerator pedal move when you press the clutch. I removed the gearbox again, removed the pressure plate and I couldn't see anything wrong with it, so I refitted it and its still very stiff. The only thing I can think the problem is the pressure plate, this was replaced about 5 months ago and worked fine before the cable snapped... Any suggestions? Thanks, Dan Share this post Link to post Share on other sites
welshpug 1,666 Posted April 25, 2008 is it BE1 or BE3? if its BE3 or Mi16 BE1 did you replace the release shaft bushes? Share this post Link to post Share on other sites
Pob 1 Posted April 25, 2008 is it BE1 or BE3? if its BE3 or Mi16 BE1 did you replace the release shaft bushes? Its a BE1 Thanks, Dan Share this post Link to post Share on other sites
gerlewislewis 0 Posted April 26, 2008 this might be a bit obvious but is the routing of the cable ok? not caught around something? Share this post Link to post Share on other sites
2-Pugs 57 Posted April 26, 2008 I had a problem with a clutch a bit like this before, it turned out to be the pivoting arm, I think it was seized, or dislocated somehow, that was casusing it to be very stiff. Share this post Link to post Share on other sites
Pob 1 Posted April 27, 2008 this might be a bit obvious but is the routing of the cable ok? not caught around something? Thanks for all the replies. I've tried the cable round different ways, I've even ground a bit of the plastic near the bolt end as I thought it was fouling... I've had the arm out, it was free anyway but I greased it all and still the same problem. Anymore ideas? Thanks, Dan Share this post Link to post Share on other sites
chris1986 1 Posted April 27, 2008 try disconnecting the cable from the box side and see if its still stiff, should narrow it down for you Share this post Link to post Share on other sites
Pob 1 Posted April 28, 2008 try disconnecting the cable from the box side and see if its still stiff, should narrow it down for you I've tried pressing on the clutch fork by hand and I carn't budge it, but then again is it possible on one working perfectly? Thanks, Dan Share this post Link to post Share on other sites
jackherer 543 Posted April 28, 2008 I've tried pressing on the clutch fork by hand and I carn't budge it, but then again is it possible on one working perfectly? Thanks, Dan Thats normal. I think Chris meant to try the pedal with just the cable connected. Although you should be able to tell from the gearbox end of the cable with it disconnected, it should move very freely by hand. Share this post Link to post Share on other sites
gerlewislewis 0 Posted April 28, 2008 is it still drivable? Ie able to change gears while disengaging the clutch? Share this post Link to post Share on other sites
Pob 1 Posted April 28, 2008 is it still drivable? Ie able to change gears while disengaging the clutch? Yes the cable is free and so is the clutch pedal. It is drivable and you can change gear no problem but when you release the clutch its doesnt release as it should, you can lift your foot off the pedal and it will come up slowly Thanks, Dan Share this post Link to post Share on other sites
Pob 1 Posted April 29, 2008 Yes the cable is free and so is the clutch pedal. It is drivable and you can change gear no problem but when you release the clutch its doesnt release as it should, you can lift your foot off the pedal and it will come up slowly Thanks, Dan I have a quick question, I need a couple of torque settings for the flywheel bolts and clutch release plate to flywheel Many Thanks, Dan Share this post Link to post Share on other sites
Pob 1 Posted May 2, 2008 I have a quick question, I need a couple of torque settings for the flywheel bolts and clutch release plate to flywheel Many Thanks, Dan Good News, fixed it. I fitted a new clutch kit only to find it was still stiff The only thing left which I replaced was the clutch cable (Motorfactors) bought a genuine one, problem solved... What a waste of time, effort and money... Sometimes Motorfactor parts are pap, lesson learnt I thinks. Thanks for all your help, Dan P.S Anyone want to buy a 1.9 GTi Valeo 3 piece clutch kit? 1500 miles old Share this post Link to post Share on other sites
