mafo
Skip Brown Rear Neg Camber Kit
mafo
Has anyone got a picture of this kit or a car using it?
I spoke to Skip Brown cars to get a bit more info, turns out that it adds an extra 9mm width to each side.
dean
hi i have this kit and you carnt really that it sticks out more than standard
mafo
Are you able to post a picture so i can see how much neg camber?
GerLewisLewis's SBC 205 has these, doesnt look noticaby wider, due to the top of the wheels sitting in a touch compared to a 309 beam.
gerlewislewis
yeah I have this, if you need a specific picture I can take one tomorrow - just tell me what angle and what your looking for exactly and I will try to capture it.
PM me your mobile no. and I will send it through as a media message
mafo
Sounds good, the only problem is that my uk company sent me a blackberry and i dont seem to be able to recioeve mms on it via my swedish network. If you can arrange some other way can you take a picture of either wheel from the back looking forward showing the wheel arch and angle of the camber and then from the back of the car showing both wheels - and then also let me know what wheels you have.
Many thanks.
Super Josh
Look here to see how far the wheel sticks out on my car :rolleyes:
Josh
gerlewislewis
i can do this, but will have to wait till monday to post the pics as my laptop at home does not have bluetooth.
Has anyone fitted a neg camber kit to a 309 beam on a 205?
mafo
Cheers josh, I am using pts sl434 wheels with toyo 888's 195/50 15 so i think this kit will be perfect!
Super Josh
No problem :wacko: I think I'm running 195/50 x 15 Eagle F1s in that picture. I reckon it makes the wheels fill the arches nicely with the extra width too.
Josh
Spiky
whats the price of the kit? and what does it consist of??
markw
i think the kit is £200 plus vat
and it consists of
2x 405 stub axle pins machined to fit a 205 arm also machined with a slight crank/kink in it
2 ali spacer plates that bolt to the arms were the caliper bracket bolts on, basically a 10mm thick rectangular piece of ali with a big hole in the middle for the stub axle pin and 4 holes in each of the corners for bolting to the arm
4 longer cap head bolts for bolting to the arm
thats about it i think it was about 3 years ago when i bought mine
