thrasher 0 Posted April 22, 2008 hi there,just bought a 205 1.9,with seized rear beam,can i swap the discs etc onto a 1.6 beam and if so is this an easy job. cheers gus Share this post Link to post Share on other sites
RossD 44 Posted April 23, 2008 You'll need to knock/press out the 1.9 stub axle and use it on the 1.6 beam, otherwise it'll all fit fine. Share this post Link to post Share on other sites
ifcho 0 Posted April 23, 2008 Yes, I have done the above. You just need to get the stub axles out and the flange that holds the caliper. Then just press the stub axles again on the drum beam and mount everything else. With a hydraulic press it's a 1 hour job. Share this post Link to post Share on other sites
thrasher 0 Posted April 23, 2008 Yes, I have done the above. You just need to get the stub axles out and the flange that holds the caliper. Then just press the stub axles again on the drum beam and mount everything else. With a hydraulic press it's a 1 hour job. cheers guys,should be able to do that ok. Share this post Link to post Share on other sites
