thrasher
Swap Rear Drums For Discs
thrasher
hi there,just bought a 205 1.9,with seized rear beam,can i swap the discs etc onto a 1.6 beam and if so is this an easy job.
cheers gus
RossD
You'll need to knock/press out the 1.9 stub axle and use it on the 1.6 beam, otherwise it'll all fit fine.
ifcho
Yes, I have done the above. You just need to get the stub axles out and the flange that holds the caliper.
Then just press the stub axles again on the drum beam and mount everything else.
With a hydraulic press it's a 1 hour job.
thrasher
cheers guys,should be able to do that ok.
