GTI6BOY
Very Urgent Clutch Cable Help Needed
GTI6BOY
Trying to change my clutch cable but something is wrong?
I have a xsara vts box and an early style clutch pedal.
my new cable has an identical end which goes to the pedal
shown here
my new cable is 100mm shorter than my old one but still clips to the subframe
now the new end has a d shape plastic clip which does not fit in the clutch release arm, so i have had to remove it, but you run out of thread and the pedal is still flat on the floor?
the old cable
the new cable
my car is now off the road till i can work out whats going on
dean
the plastic bit on the cabel pushes in to a u shape on top of the box and then just put the cabel as normal in the cluch arm
GTI6BOY
the d shaped plastic bit does not fit if you take it off then you run out of thread
dean
i have just had another look at the photos and it looks like you have a push clutch set up and the cabel you have is for a pull clutch. have you tried putting all the rubbers off the old cabel on to the new cabel that may work
GTI6BOY
i have tried that didn't work
Is that a BE1 or BE3 cable? which ever one it is you need the other as it is longer, Easier to fit the correct clutch next time around as it saves all this hassle
GTI6BOY
funny you should say that as i have just seen on service box and the be1 cable looks like it would fit?
the clutch has been in the car since i purchased the engine about 4 years ago
new cable you have is BE3 push type, old cable looks to be BE1 push type.
IIRC there are 2 types of BE1 cables, where the bulkhead end fitting is like BE3.
GTI6BOY
thanks i have a be1 cable coming tomorrow with the same pedal end as i have...will let you know how is goes
GTI6BOY
was a late be1 cable i needed...job done
cool! which car is this in?
GTI6BOY
this is in the cti with be3 gearbox
