mwilcock
Xu10j2te Questions
mwilcock
question 1: three plugs at the back of the lump, brown, green and blue. whats what?
question 2: map sensor pipe, off the ecu? where does it go?
question 3: on the back of the engine but on top, there is a rubber pipe, (that connects to the silver boost pipe from the turbo) and it has some form of relay in it to where a plug goes? what is this? what does it do?
any help would be most grateful and im sure ill add more questions
Mike
tom_m
1. on the thermostat housing? water temp sender for dash/ecu and err something else.
2. to one of the nipples on the throttle body
3. the boost control solenoid. should be three pipes on it. one to the intake piping, one to the boost piping and one to the waste gate actuator
mwilcock
what colour is the water stat?
which nipple, as i dont think i have any pipes left, one of them is doing my swirl pot, shouldnt it?
and i dont think i have 3 pipes, bollocks lol
o and if i buy an a/f gauge, does it have to be wideband because its turbo?
Edited by mwilcock
tom_m
i think you need to take some pictures, post em up and we'll be in a better position to help.
edit:
depends what you want it for. wideband has much more resolution, so is far more useful, a narrow band guage is just there to look pretty :)
Edited by tom_m
sonofsam
Mike
http://forum.205gtidrivers.com/index.php?s...63&hl=turbo
mwilcock
well heres a pic of the throttle body plus pipes, which one goes to the ecu?
right, well i want to measure my a/f so i dont run it too lean...
i thought the plug was somewhere else for the water temp but it must be one of those at the back of the engine, either green, blue, or brown..... its usually blue on pug but, wonders never cease..
Edited by mwilcock
tom_m
that one :)
brown would be for the fan in the original installation, Bitron sensor for A/C controlled cooling fans, green would be ECU, blue for the dash.
mwilcock
so if i put on a mbc i can ditch that thing?
and green for the ecu?
Edited by mwilcock
tom_m
if you're using an mbc you can ditch the boost solonoid yes. you might need to keep it plugged in to prevent the ecu registering a fault tho.
blue for the ecu if it follows 205 colours
Edited by tom_m
mwilcock
amy ideas on which mbc to go for, anyone reccomend one?
tom_m
i'm using a dawes device without any problems at the moment. not meant to be as spikey as bleed valves.
mwilcock
never heard of it tbh, can you buy that off ebay?
later systems don't follow the 205, greeeen it is for the ECU :)
Edited by welshpug
tom_m
i stand corrected :wacko:
sonofsam
Been there, done that, gone back to ECU controlled booooost :excl::):) way smoother :wacko:
mwilcock
ok which one goes back to my dials for the water temp?
and what does it go to the ecu for? dont think ive wired it up properly, ive just wired mine to run and run into problem after problem :)
its like a bloke putting together a wardrobe the reading instructions after :wacko:
tom_m
Been there, done that, gone back to ECU controlled booooost :DB);) way smoother :P
i went back to the darkside. the difference between 0.4 and 0.8 bar is hooooooooooooge! *insert evil grin here*
woosh boooooooooooost :P
mwilcock
ok lets lowering the interlect here for me for one sec
if i buy a mechanical boost controller, i can ditch the boost solenoid
i can then wind the boost up to nearly 1 bar and that will improve bhp? what bhp am i looking at ish?
craig f90
and what does it go to the ecu for? dont think ive wired it up properly, ive just wired mine to run and run into problem after problem ;)
its like a bloke putting together a wardrobe the reading instructions after :P
Blue goes to your dials. One pins stop light others temp gauge. I think 1st pins temp gauge. just swap em around till they work? Green tells the Ecu what temp the engines at? must be important.
Brown is to Bitron sensor works with aircon and fan or something, Haynes literature baffles me.
craig f90
Not sure about these mechanic boost controllers.
1bar should see you past 160bhp surley?
mwilcock
good job i havent wired the ecu fault light thing up , it would never go off the amount of things ive missed ;)
and 160bhp? :P i was hoping for 200 ish
Edited by mwilcock
all being well 1 bar should see you well over 200bhp ;) as to whether everything else is up to it is another matter, I'll leave answering that to the Turbo boys.
tom_m
1 bar with the standard ecu will see you hitting nothing but the boost cut.
