DamirGTI 344 Posted April 20, 2008 Hello ! As above , which tool is best for removing spot welds , this plain spot weld drill : (available in various sizes : 6 , 8 and 10mm) or this spot weld cutter : (available with just one size of cutter : 9.6mm) Thanks ! Damir Share this post Link to post Share on other sites
swordfish210 20 Posted April 20, 2008 I used a spot weld drill bit when i was taking out my seat mounts which worked pretty well. As well as a 2lb hammer and a cold chisel Share this post Link to post Share on other sites
DamirGTI 344 Posted April 20, 2008 (edited) Well , i've been using just plain drill bit (7mm.) and a flat shapr chisel ... and made a real mess - Swiss chesse , first i've over done the spots and drill them all the way inside trough both panels , and next i've tried with just a little bit of drilling on the top panel and then hammering with the chisel from the edge , from the gap of both panels on the spots , but then i rip of the lower panel around the spot weld damn ... Damir Edited April 20, 2008 by DamirGTI Share this post Link to post Share on other sites
toddydal 1 Posted April 20, 2008 yes spot weld drill or you could get the proper tool its called a spotle, you set it to the right depth so you dont drill right through,,,, quite expensive tho Share this post Link to post Share on other sites
Rom 0 Posted April 20, 2008 I prefer the drill bit type. The spring loaded ones always break i find. One of the teeth snap and its game over. Like many things...slow is smooth..smooth is fast Share this post Link to post Share on other sites
DamirGTI 344 Posted April 20, 2008 Ok. then i'll buy drill bit type But which size should i buy ? me thinks that the 8mm one will be the best (cos the spot weld on pug is roughly 5mm dia.) Rgs ! Damir Share this post Link to post Share on other sites
