dan1120
Rev Limit
dan1120
Got my carbs on so no longer got my ecu plugged in,brought my self a omex rev limiter which gose across the coil,ive got a 281 supersport cam ,abit of head work,4branch,r1 carbs,power band says 2500 to 7000 for the cam do you think it will be safe to rev round to 7 or set it abit lower????
Application Power Band Cam Lift(mm) Valve Lift(mm) Duration Timing Full Lift VC (mm) LTDC Required Parts
Supersports 2500-7000 11.63 I 11.37 E 11.32 281 Deg 34/67 67/34 106 Deg I 0.25 E 0.30 I 3.65mm CF37 / VS52
wardy18
ive got mine set to 7000 but im running double valves springs from QEP along with the Catcam, i wouldnt suggest any more than 6500 as standard if your running standard valve springs and standard bottom end
when i get the bottom end lightened and balanced i intend to take this to 8000
