ifcho
Xu5/xu9 Oil Pump Assemblies
ifcho
Hi,
So I'm building a 1.6 motor,using a 1.9 block.
I also have both oil pump assemblies.
From what I can see visually, the crank gear for the 1.9 oil pump is much larger than the 1.6 one.
The 1.6 pump is from a `86 car and the 1.9 from a `92 128bhp model.
So now I'm wondering which assy I should use. I guess most votes would be for the 1.9 one ?
Additionally I noticed something rather strange (and most probably I have gotten it wrong) but it seemed to me that the 1.9 gear is of the friction driven type. Is this possible on a late 92 engine? <_<B) B) as in such case, I am not too keen on using it :angry:
2-Pugs
I remember years ago taking apart both a 1.6 and 1.9, I think I noticed then that the oil pump gears were different. My vote would probably be for the 1.9 which I assume would give a faster drive. But I am happy to be corrected :) I wondered if it was anything to do with the external oil cooler that was fitted to the 1.9 :)
Regarding the gear, you are correct, it is simply held just by the compression of the adjoining bits once you torque up the crank pully bolt. Seems a bit odd to me, but perhaps there is good reason for it. I have seen engines where this is pulley is driven by means of a woodruff key in the crank, seems a lot more obvious, why that wasn't continued, I dont know.
I made the mistake of starting mine up once before I tightenend the crank pulley up, I think it was after I'd done the cam belt or something. For a few seconds, I wondered why the oil pressure needle was flicking up and down randomly, then I realised the oil pump wasn't getting a good drive - d'oh :o Fortuanatly no lasting damage was done
