Arahan
Gearbox Reverse Light Switch
Arahan
After my reverse lights not working, and talking to Graham (Pugtorque), checked my wiring and fitted both spade connectors and the lights came permenatly on. After much fiddling and checking of wires and fuses, all seems as it should be yet they are still on, so we think its the gearbox reverse light switch has given up!
What I want to know is, where can I buy one from? Any local motor factors? Do I have to go to Peugeot specifically?
Thanks in advance! - James
jord294
there are 2 types available.
the be1 switch is longer than the be3
ALEX
Scrap yard a good start.
Chances are they're the same as most other Peugot/Citreons.
I don't know for sure though?
It could be the plug to the switch is faulty or just full of dirt.
ablister
try peugeot, it may be cheaper than you think (but probably not)
DrSarty
I've got a spare. £3 posted.
RICH
Arahan
Its a BE1 switch that I need then, if there's a difference! Though I don't mind not having any reversing lights, I'd like to fit my bumper mounted phase 2 reverse light! :P
