ryangti
Carbs On A 1.6 And Fuel Line Question
ryangti
hi i have a pair of 40's that were previously on a 1.9 gti, i was wonderign if anyone could give me a rough estimate to the jet and emulsion tube sizes i will need for the 1.6? the spec is
shenpar stage 3 head, racing cam (cant remember spec), standard manifold but full omp exhaust.
also what is the inner diameter of the fuel hose?
thanks
ryangti
anyone?
Might be worth doing a search. I think Longun has a vaguely similar set up. :mellow:
Longun
Ryan,
As per the PM i'll dig the info out and pop in on here so it will also help others :rolleyes:
taffycrook
fuel hose is 8mm ID.
40 DCOE need 34mm chokes
140 mains
180 airs
40 pump jets
emulsion tubes should be ok as they are, as should the idle jets and airs.
For weber 40s? I need to start getting the bits for mine soon!
