Henry 1.9GTi 36 Posted April 12, 2008 What is this pipe? is it from a citroen bx, im not sure why I think this but can't search for bx. Need to indentify it as mine is shot. Sorry no pics as car isnt with me atm. Cheers. Henry. Share this post Link to post Share on other sites
GLPoomobile 958 Posted April 12, 2008 Errrrrrrr, bit of a vague post!! Are you asking what pipe to use if converting to the bigger VAG throttle body on an Mi? Share this post Link to post Share on other sites
Henry 1.9GTi 36 Posted April 12, 2008 (edited) no its already converted. unsure as to what/where the pipe came from. i cant be any more precise other than that I need what ever pipe it is, ill get some pics up next week. Edited April 12, 2008 by Henry 1.9GTi Share this post Link to post Share on other sites
GLPoomobile 958 Posted April 12, 2008 From what I can remember of reading about this a long time ago, you can just use an original 405 Mi pipe. You just need to heat it in hot water and stretch it on to the TB. Share this post Link to post Share on other sites
Simes 248 2 Cars Posted April 13, 2008 no its already converted. unsure as to what/where the pipe came from. If you're running Dino's old engine then I think this VAG mod was done by Hi flow heads. Share this post Link to post Share on other sites
maxi 36 1 Cars Posted April 13, 2008 The 405 mi16 or BX16v induction hose will do the job no problem. The BX item is longer however, so can give AFM & cone filter fitting a bit tricky. I usually cut down the BX hose down to fit it all in. Maxi Share this post Link to post Share on other sites
Henry 1.9GTi 36 Posted April 13, 2008 thanks for the info guys, i'll stick up a wanted post. Henry. Share this post Link to post Share on other sites
