allanallen
Yet Another Turbo Project
allanallen
evening, any one know how an xm turbo engine gets its low comp ie, is it in the pistons or the head, i'm assuming its the rgx engine.
I have a very high milage engine and am guessing the bores will be fooked so was curious about swapping the bottom end for a standard 1.9 or 1.6 bottom end.
ive read through loads of stuff on turboing the low comp cat engine (like henry uses) but cant seem to find any info on this swap? help me :( cheers al
M@tt
have you pulled the engine out yet? if not get your finger out and get it out and the head off it :(
allanallen
car should be in the garage on sunday hopefully :( now back on topic mathew
sonofsam
XM will be RGY (140ishBHP)
Pistons I think.
Iron block for Turboing- Thems the rules :(
allanallen
Pistons I think.
rules are there to be broken :(
can anyone confirm its in the pistons, then i'll give up with my stupid cheap skate ideas
whizzer71
Yep the low comp is in the dish in the piston (somewhat deeper compared to a std XU10 8v piston),I can post some pics tomorrow for you for comparison.
Never compared a XU10 N/A head along side a turbo one so cant comment on that one.
Take a look at the drivers web site projects,theres a alu engined one on there with XU10 turbo and components
allanallen
I'll take a look at that, cheers
right so, the rgy uses cut outs in the pistons to lower comp
does the rgx engine use the flat top pistons with bigger bowls in the head to lower compression then?
whizzer71
Not sure which way around it is,I'll get the code off my engine and post it along with a pic of a piston,This topic has been covered on here before with relevant comp ratios and piston types etc (Ie the difference between the RGY/X engine)
Henry Yorke
Mine is one of these and you have seen how that flies Al!
I think the XU10 is in the pistons as has been said. The XU9 I use has its low comp in the head and a touch in the pistons.
Might have an outlet for any XM parts as my mate has one! Just had to buy a new exhaust centre section for it and returnofjim did the headgasket too B) It is my doner when he hydrospastic suspension goes as the engine and turbo are mint :) Just not sure what to put it in!
28CRAIG
The head is the same cc on all the xu10 heads 36cc i think but is 34cc on the xu5/9
inferno
The RGX is a higher compression engine than the RGY IIRC... heads could and probably will be the same.
tom_m
nope the low comp engine uses the flat top pistons
no the rgy (low comp) has the flat top pistons and the RGX (high comp) has the dish
correct
whizzer71
So if the low comp has flat top pistons how does it achieve its lower compression,Dont mean to contradict just that normally to get lower compression you dish the pistons ?,I assume that the head volume (36cc) is the same on both engines ?
:lol:
whizzer71
correct
I was reffering to a comparison of the normal 2.0ltr N/A engine which also has marginally dished pistons just not as dished as the turbo ones not between RGY and RGX
tom_m
:lol:
i've not measured anything, just reporting what i've seen when taking these engines apart.
i assume (yes the mother mother of all f*ck ups) that the dish is built up higher than the top of the flat tops to create more squish or whatever.
certainly the top of the flat top piston is still quite a way down the bore at TDC
whizzer71
Hey Tom just looking at your intended spec at the bottom of you sig,you got any pics or a link to pics that you may have ?
Tris
Edited by whizzer71
allanallen
right, bit of an update. ive got the car home now and ive quickly done a compression test this afternoon, the results were
85-60-50-145psi
and the intertcooler pipes are full of oil. i'm now thinking this engine will be better left in the car and sent for scrap. :(
inferno
whip the head off and have a look, probably a head gasket and maybe turbo seals. certainly not worth scrapping without taking the head off though.
tom_m
Tris
There are some pictures here :(
allanallen
i'm on it this weekend :)
returnofjim
I recently did a head gasket change on an xm turbo and it had very deep dished pistons. Ive looked at internals on almost all xu engines and those turbo pistons were different to any others ive seen, whereas all the chambers in the heads looks very similar. Whatever you do dont scrap it, give it to me :(
allanallen
I recently did a head gasket change on an xm turbo and it had very deep dished pistons. Ive looked at internals on almost all xu engines and those turbo pistons were different to any others ive seen, whereas all the chambers in the heads looks very similar. Whatever you do dont scrap it, give it to me <_<
be interesting to see whats inside then
not scrapping engine anymore regardless of condition, i'm gonna have a swap round with my engines now, so this ones destined for my 309 (albeit breathed on a bit) now and i'm gonna be finishin off the supercharged mi for in my white 205.
Henry Yorke
My brother has a low comp 1.9 engine if you want to make a super skip like mine!
whizzer71
Pics of pistons as promised Normal 2.0ltr 8v and Turbo 2.0ltr 8v
allanallen
ive had the head off mine now and it has flat top pistons, at tdc the pistons are about 10mm off the deck.
its also got some big ass ridges at the top of the bores ;)
