richard 0 Posted April 11, 2008 Some of may remember i had all sorts of problems 4-5 months ago with the cars earthing and it not starting. I replaced a fair number of bits on the ignition and it now starts etc every time But, the biggest thing for me which im not sure off is when using above 5krpm, the rev counter appears to jump around a bit. Am i right in thinking i could have a dodgy ignition amp(it was replaced)? Or a cable/plug problem attached to it? I should put out that the performance is not affected. Share this post Link to post Share on other sites
DamirGTI 342 Posted April 11, 2008 Hi ! Did you check the dizzy signal cable ? (the one which goes from the dizzy to the ignition amp. connector) Rgs ! Damir Share this post Link to post Share on other sites
