Bakes100
Top Mounting Cracked :(
Bakes100
The threaded base that my top mount attaches too seems to have a crack in it :P
Has this happened to anyone else?? if so how easy is it to repair?
Edited by Bakes100
James_R
happen's just needs welding up and maybe a plate adding to add some strength to things. very common on 306's
Bakes100
Cheers for the quick reply
Yea it looks like it just needs welding as its just split.
If i plated it for reinforcement would i have any mc clearance issues as surely it will raise that side of the engine slightly??
Is there any way around this?
Edited by Bakes100
sutol
Won't it lower the engine or have I got the wrong mount ?
fletch
Na hes talking about plating up the drivers side mount, hence raising the engine by a few mm.
