fabian
Dampness Inside
fabian
hello was wondering if anyone can help, i have noticed a damp patch near the front seat mount at the back of the runner by the drivers door, any likely places to search for the hole? and also my car seems to drip water out of the underside of the car around the middle there is a circular hole, was hoping to solve it to prevent rusting. any help would be much apprieciated.
brian j
It may well be your side window seals leaking, but I think you will find you will get more help from everyone on here if you have a little search of the forums before asking the question, because this has been covered a lot of times.
Good luck sorting it.
fabian
ok cheers, sorry about that have now searched and found it covered, just got to find the leak now.
fabian
hello, Had a closer look and ended up ripping all the carpet and seats out as all the sound insulation was soaked, the water is coming in down the passenger side of the bulk head, thought it was the rubber bungs in the wheels arches but has filled up over night whilst being stationary. so probably not ?! whats the easiest way to see the seem of the bulk head? is it a dash out job ? and whats the best thing to seal it with ?
Hardgraf
I discovered a puddle under the passenger seat today. Hope It's just the rear window seal!
fabian
good luck finding it I ended up taking the carpet out and found the leak was from the windscreen. nice clean carpet now tho!!
