Guest Lisa
Best Oil To Use
Guest Lisa
I have a 92 1.6 gti, whats the best oil to use in it?
GTI6BOY
10w 40 semi
Hi and welcome to the club ;)
Just to add to the above, depends how many miles it has done in my experience. I run 15/40 in my 136k mile 1.6 as this allows it to maintain good hot oil pressure where the 10/40 would not.
Henry Yorke
Personally I have always found that 205's like Millers XS-s 10/40W Semi synthetic. Always use a Peugeot oil filter on them though as they have a return valve in them which keeps the pressure better
base-1
Another vote for Millers being the shizzle ;) Champion filters also have the valve, think Frams do aswell but I forget. Either way should be cheaper than Peugeot!
I can get oe Peugeot / Citroen filters for £2.50 from my local motor factors.
base-1
Small local one? Nobody round here sells Purflux :D And we have "South East Tax" on everything here too :P
CaptainK
:P
Huh? Unless I'm misreading Oilmans posts and so forth the 15 in "15w40" relates to its viscosity when cold and the 40 relates to the viscosity when its hot. So a 10w40 and a 15w40 should both have the same viscosity when at the same "hot" temperature.
I use a 5w40 oil myself as I need the cold start protection as I do a lot of short distance driving.
jonnie205
miller sis very good i was sponsered by them for 2 years in my rallying. Its expensive but the quility is top notch especially in valuable motorsport engines
