Guest dunk Posted April 7, 2008 Does the RGX (150bhp) motor from a 96' Activa have a recirculating dump valve? Cheers Share this post Link to post Share on other sites
bales 1 Posted April 7, 2008 Does the RGX (150bhp) motor from a 96' Activa have a recirculating dump valve?Cheers Some do some don't in my experience. Share this post Link to post Share on other sites
sonofsam 5 Posted April 7, 2008 Some do as stock, some dont. (French randomness!) My RGX didnt, I dont run one at all now If it has one it will be on the cross-over pipe usually. Share this post Link to post Share on other sites
Guest dunk Posted April 7, 2008 (edited) Some do as stock, some dont. (French randomness!) My RGX didnt, I dont run one at all now If it has one it will be on the cross-over pipe usually. Cross over pipe? Wheres that? Edited April 7, 2008 by dunk Share this post Link to post Share on other sites
sonofsam 5 Posted April 7, 2008 Boost pipe that crosses over the end of the rocker cover from rear to front: That one has a recirc. valve btw. Share this post Link to post Share on other sites
Guest dunk Posted April 7, 2008 Boost pipe that crosses over the end of the rocker cover from rear to front: That one has a recirc. valve btw. Cheers Sam, in that case, mine hasn't Thought it chattered a little to much to have a bov One thing that confuses me, you can't really hear it unless you remove the induction filter, maybe need to wind the mbc a bit more? Share this post Link to post Share on other sites
sonofsam 5 Posted April 8, 2008 Cheers Sam, in that case, mine hasn't Thought it chattered a little to much to have a bov One thing that confuses me, you can't really hear it unless you remove the induction filter, maybe need to wind the mbc a bit more? I hear mine on every shift, cone filter and vented bonnet makes sure of it :wub: Share this post Link to post Share on other sites
craig f90 0 Posted April 8, 2008 I hear mine on every shift, cone filter and vented bonnet makes sure of it :wub: Mine came with a bailey chav valve. Took mine to a local garage last week and the mehanic said " should it make that noise out of the air filter? odd that." To which i could only reply, "Okay...Your the mechanic, you tell me?" Another lesson learned on here today. Share this post Link to post Share on other sites
