5150maxie 0 Posted April 7, 2008 can i set the ride height with out removing the one end of the torsion bars on on side? what i mean is i have removed both trialing arms(renewing bearings) but can not removed one end of the torsion bars? Share this post Link to post Share on other sites
welshpug 1,657 Posted April 7, 2008 try a bit harder which end is stuck? you'll struggle to get a decent ride height without removing both ends. Share this post Link to post Share on other sites
5150maxie 0 Posted April 7, 2008 try a bit harder which end is stuck? you'll struggle to get a decent ride height without removing both ends. torx screw end attached the the trailing arm. Share this post Link to post Share on other sites
welshpug 1,657 Posted April 7, 2008 taken the torz screw out? adn the offset washer? if so hit it harder it will come out. Share this post Link to post Share on other sites
5150maxie 0 Posted April 7, 2008 taken the torz screw out? adn the offset washer? if so hit it harder it will come out. the torx screw want move i dont want to snap it or round it of.i will put loads of wd40 on. Share this post Link to post Share on other sites
Anthony 1,003 Posted April 7, 2008 If that end of the torsion bar is stuck in the trailing arm, you'll be limited to adjusting the ride height in approx 35mm increments.... the so-called "splines" method of lowering Share this post Link to post Share on other sites
5150maxie 0 Posted April 7, 2008 If that end of the torsion bar is stuck in the trailing arm, you'll be limited to adjusting the ride height in approx 35mm increments.... the so-called "splines" method of lowering cheers for that i understand now will try harder Share this post Link to post Share on other sites
stutto 0 Posted April 8, 2008 Buy a replacement and drill out the old one, I had to do this on both of mine. Getting the bolt out is only half the battle though...the washers can be a right PITA too. Share this post Link to post Share on other sites
