skinner2k3
A Few Engine Rebuild Questions….
skinner2k3
If the crank bearing surfaces (not the journals themselves) look undamaged and measure within tolerance can a standard set of new bearings (big and little end) be ordered, or are they only supplied with a regrind?
Is it possible to do a compression check on an engine out of the car with no gearbox or starter attached?
Will a 1900 clutch fit a 1600 fly wheel?
Anyone got any ideas for getting the treaded part of a spark plug out of a cylinder head having sheared off the hex and core?
Excuse any stupid questions, havent rebuilt an engine before.
Ben
M@tt
a) yes you can get a standard set of bearings
:) No i don't think so you need to turn the engine over at a reasonable rate(certainly quicker than by hand) and you'll need gearbox on to mount starter properly
c) yes flywheels and clutches are the same
d) you'll need to take it to a machine shop and get them to drill it out and helicoil or retap the thread
skinner2k3
Thats good then. I know of a local machine shop that will probably be able to get the spark plug remains out and supply the bearings.
I do have a gearbox in the garage and a XU10 starter I intend to use anyway so I will get that bolted together to turn it over. I thought there may have been a leak down test that could be done statically.
skinner2k3
Another question...
Which parts have to stay together and which can be mixed and matched?
I have a complete 1900 engine in the car and running with good oil pressure, new head gasket, water pump belt and had a complete service last year. Miles heard this one running last year and IIFC believed the bottom end rattle sounded a bit big end like.
But in the garage I have another complete runner, 2 spare blocks (1 x 1900 and 1 x 1600) and 3 spare cylinder heads. Its out of this lot I would like to build up a good engine to replace mine if/when it sh*ts itself.
I am sure I have enough bits to find a good example of each part required but dont know what can be mixed. I will fit new bearings as a matter of course so can I use which ever are best?
Sandy
If you have the gear available, you can do a leakdown test on a static engine. A useful guide to the sealing properties.
