205toby
Fuel Surge- Anyone Else?
205toby
As the title says..
Am I the only one that gets fuel surge? It seems to do it at anything less than 1/2 a tank. Very anoying and I really don't want to run any more than half a tank on trackdays.
I've been thinking of a boot mounted surge tank and external Bosh pump. Anyone done anything similar?
Cheers and thanks in advance!
Toby
Its a fairly common problem, there are definitely other threads on this subject.
try searching for:
+fuel +surge
and make sure you are searching all forums.
I found this straight away: http://forum.205gtidrivers.com/index.php?showtopic=78725
Pugnut
i got terrible problems with this after fitting an early pump to a late tank . the pickups/sumps are different and when mixed give pretty poor results.
what is the year of you're car and does the fuel pump have a connector directly on it , or short wires app 3" long then the connector ?
Al
Spiky
i used to had surge , dont now :)
click my build :)
Edited by Spiky
Nathan
Mine gets it real bad, 1/2 on the road and just less the 3/4 on track!
When I pull my finger out I'm going to strip and inspect the pump (not sure if thats possible) as its probally a good few years old. If this doesn't improve things I'll rig up a fuel swirl pot with a secondary pump to feed it.
Change to the other type of pump, i've found it's been that in my cases before.
quite a random one this, my car doesn't suffer from it till its practically empty!
Garry
Your obviously not cornering fast enough then :(:wacko:
I get fuel surge since changing pumps, although this will be cured when I fit my Swirl pot and external Walbro pump.
You changed to the wrong pump then! :)
Your obviously not cornering fast enough then :):)
says who?
Garry
Using the kerb to make it look like you are going fast is cheating!
Spiky
Rippthrough
Look at the bus queue waiting to come past :(
Jrod
Some of have swirl pots as standard. :D
