DamirGTI
Ms Base Ignition Map For 2.0 T Engine
DamirGTI
Hello !
As above , can anyone offer base ignition map settings for 2.0 T engine running on Megasquirt ECU ? :lol:
Thanks !
Damir
DamirGTI
... :) no one ?!
Hi Damir. Up until 0kPa, a NA and turbo map are the same. So use one of the maps posted in this section to start with. Once the boost comes on, the advance needs to be retarded. So assuming you'll have 30 deg. @ 0kPa, I'd gradually run back to 24 deg. on full boost to begin with, until you can do it properly on a dyno.
Edited by petert
DamirGTI
Thanks Peter ! :)
Damir B)
DamirGTI
Nice one B)
Thank you ! :D
Damir
