smokey 0 Posted April 2, 2008 Hiya guys I've just taken off my drivers side wing because it was starting top rust badly and had a hole in the bottom. (Blow torch method for getting the seal to give worked a treat!) Now i'm just trying to work out how to get the new wing back on. I can see these 2 clips near the door. Here is a picture I tried pushing the wing into them so that the clip will hold the wing in place but no joy, is there a knack to it? Thanks Share this post Link to post Share on other sites
brianthemagical 1 Posted April 2, 2008 have a look inside the car, there is some trim you need to remove, then a 10 mm bolt, use a long socket/extension otherwise you might lose a 1/4" rachet forever, ahem. Share this post Link to post Share on other sites
smokey 0 Posted April 2, 2008 have a look inside the car, there is some trim you need to remove, then a 10 mm bolt, use a long socket/extension otherwise you might lose a 1/4" rachet forever, ahem. Wicked, thanks for that. So put the clips on the wing 1st then bolt the clip in place. Makes allot more sense!! Share this post Link to post Share on other sites
