BossHogg
Indicator Loom
BossHogg
The front near side indicator doesn't work, i have checked the usual suspect namely the hazard switch. However ever after con checking the loom i have found that the portion between the plug the front indicator and the side repeater is fecked.
Now do i try and make up a new loom myself, how hard could this be? or does anyone now where i can get another one?
BossHogg
Cancel that, quick phone to the local scrappy and problem solved, phew i didn't fancy mucking about with making up a section of wiring loom.
