justinv 4 1 Cars Posted April 2, 2008 (edited) so some light questions bout an mi, 1.From these two boxes which one is the better on an mi..., 1.6 BE1, 1.9 BE1(from a bx) 2.Which bodies are best for it ? 3.Does a 1.9 8v block fit directly on an Mi Head ?( what do you have to replace ) 4.Are the standard 1.6 brakes fit for an Mi ? 5. ...... as well as 1.6 driveshafts? Still.. undecided what engine change ... thanks for your help. Edited April 2, 2008 by justinv Share this post Link to post Share on other sites
M_R_205 5 1 Cars Posted April 2, 2008 1.From these two boxes which one is the better on an mi..., 1.6 BE1, 1.9 BE1(from a bx) That depends if you want out and out acceleration(1.6) or or a litle refinement (1.9) 2.Which bodies are best for it ? What are the options? 3.Does a 1.9 8v block fit directly on an Mi Head ?( what do you have to replace ) im not 100% but im sure the oil ways dont match up, but a bit of engineering and it can be made to fit, also you will need a second belt tensioner in there somewhere 4.Are the standard 1.6 brakes fit for an Mi ? Yes but id personlay upgrade to 1.9 5. ...... as well as 1.6 driveshafts? As above, but will require 1.9 hubs) Hope that helps Paul Share this post Link to post Share on other sites
justinv 4 1 Cars Posted April 3, 2008 thanks very much regards Justin Share this post Link to post Share on other sites
