shooter mcgavin
Trouble With Cooling Fan
shooter mcgavin
since i bought my car the cooling fan has never worked,proplay what cause the last owner to melt the head then the big ends.
now that the 6 engine is in and running this would be a good time to sort it out.
ok. the blue plug that goes to the rad switch looked in a bad way (half melted) so chopped 1 from a breakers as per pic.
1st question. whats the brown plug for
2nd. i have power going to the blue plug and when i add a live to the main fan wire from the battery i have lives from the 3 wires from the plug, the relay is live so is it just a buggred rad fan switch?
sorry if this sounds confusing but its the only way i can try to understand what part is at fault
cheers
graham.
Edited by shooter mcgavin
The brown plug is just there as a test loom, doesn't plug in anywhere but if you bridge from the centre pin out to either side the fans will run at either low or high speed.
There should be just one live to the fan switch / blue plug & then each feed is to the resistor for the fans afaik.
I did have a spare loom for the fans somewhere, its only a short loom that runs between the shunt box, resistor & radiator switch.
I'll have a look for it tomorrow hopefully & post what I figure out.
woodsy
hi mate.I may be wrong here but iam sure that the brown plug goes to earth point behind the passenger headlamp area.Iam sure it goes there.If wrong sorry.
shooter mcgavin
graham thats great,its the short loom i am trying to sort out.
dug out the old gti6 rad today am took the fan switch off it,i'll take a look in the morning and see if its the same as the 205 1.
Noooo!! Don't plug it in there!!
As Graham said it's a test loom, does nothing usually just hangs dormant...
