Guest AndyD
Uneven Tyre Wear
Guest AndyD
Hay,
Both my front tyres are worn on about a 1/3 of the tread on the inside quite badly. I am thinking the camber is out. But as you carnt alter the camber at the wishbones I am not sure.
Any thoughts?
Check the tracking - excessive toe-out will cause wear on the inside edge of both front tires
Guest AndyD
Thanks for that :( It is going for two new tyres on Friday, so will get the tracking checked then.
Simes
Knackered wishbone bushes and ball joints can also lead to this.
Guest AndyD
Just for future reference. I had two new tyres fitted yesterday and the tracking checked. The tracking was way out! So looks like that was the problem. She feels a lot better, so hope this will have solved the problem.
Thanks for the bits of advice :blush:
andrewhewitt
Thanks for the bits of advice :)
was it toeing out? i expect so, does it feel more stable at speed in a straight line now?
and you are right there is no camber adjustment on std front suspension
