Bakes100
Gti6 Water Cooler / Bottom Hose
Bakes100
Hi
After doing some searching I couldnt really find a difinitive answer for this.... Does the gti6 engine really need the water cooler system by the oil filter if its just used for fast road use??
Also if it does require it , does anyone have a part number from peugeot for the bottom hose that will connect the hose to the exchanger? (i have read it is either the 405 TD one or a BX one?)
Any helps appreciated ;)
The Heat Exchanger gets the oil hotter than anything else so the engine temp's get to the right spec when driving in most condition's, Drive them hard and it goes to pot and thats where the air cooled cooler's come into there own.
There's loads of ways of connecting it thou, Some Rad's have the take off for it, But the most common is the BX pipe
Bakes100
cheers miles , you wouldnt know the part number for the bx one would you???
craig f90
I used a SFS t peice. with no leaks. Sonosam had an outlet brazed on from the metal pipe that bolts to the inner wing and joined it that way. :(
jim205GTI
This is the part number for a bx bottom hose with the t N17912. 17.50 without the VAT
Thats from GSF by the way! ;)
Bakes100
Thanks mate :), ordered one from GSF yesterday, will i need another pipe to connect it to the exchanger or is it all in one?
