M_R_205
Window Questions
M_R_205
Just a couple of quickies,
how are the windows held onto the winderer mechanism, and is it easy to change them over?
I tryed a search and dint get much :wacko:
Paul
GLPoomobile
At the base of the window it has two metal supports which are bonded in place. These slid inside guides connected to the mechanism.
IIRC, removal involves undoing various boths that hold the mechanism in place so that you can manipulate it to get the guides away from the support brackets. Once they are free you can lift the gass out of the door (need to unclip the weather strips first though).
Not a complicated job per se, but can be quite fiddly and a pain. Use some strong gaffer tape to hold the glass in the fully up position while you are working on the mechanism.
M_R_205
Thanks for that, i was imagining it was going to be a fiddly job, there always the worse sort of jobs :ph34r:
SIDCPHIL
Helpful thread as this is my next job :)
SIDCPHIL
Original Windows out
Polycarbonate in :)
AdamP
Phil, how are yours held in place and do they make a good seal at the bottom with the original seals?
SIDCPHIL
I have used the original winding mechanism to start with. I may change that by a permanent fixing
The seals seem fine although we shall see once on track
