ccgoose 0 Posted March 28, 2008 Hi all, i'm thinking about making some upgrades to my 205 ('87 1.6 GTi) and just wondered what 1.9 parts are worth putting onto a 1.6 or is it worth just upgrading everything to 1.9 spec ? It's not used for racing or anything like that but in time it might see a couple of track days Share this post Link to post Share on other sites
Atari Boy 11 Posted March 28, 2008 Firstly, I am no expert. I do however have a 1.6 albeit with a 1.9 lump in it now. I am rebuilding a rear beam and it seemed sensible to use a 1.9 one that has disc instead of drum brakes whilst I am at it. I think the front brakes are slightly larger than the 1.6 ones too but I haven’t tackled that area yet. Share this post Link to post Share on other sites
Rob_the_Sparky 10 Posted March 28, 2008 Front brakes are the same diameter but are different physically. At a guess due to the different driveshafts and hubs. Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted March 28, 2008 Like Rob said, All 205's have the same sized discs (247mm). If everything on your 1.6 is in good condition then you don't need to change anything over to 1.9 spec just because you are thinking of doing a couple of trackdays. Decent 1.6 bits are plenty strong enough if you use good quality replacement parts when needed. Graham. Share this post Link to post Share on other sites
Anthony 1,003 Posted March 28, 2008 1.9 calipers (using 1.6 disks) is a useful upgrade if your 1.6 calipers are rubbish like most are these days. Otherwise, the rest of the running gear is fine even with Mi16 power and shouldn't have an issue with a few trackdays. Share this post Link to post Share on other sites
James_R 3 Posted March 28, 2008 Yep, 1.9 front calipers is a good plan, I'd keep the whole front running gear, its wider than 1.9 stuff, and free compared to upgrading to 309 stuff. Bar that, engine if you happen across a cheap one an can do it yourself, otherwise just a std 1.6 will be heaps of fun on track Share this post Link to post Share on other sites
16v205 9 Posted March 28, 2008 If your 1.6 brakes are ok then sell the rest and use the money to buy some good pads. You wont benefit from swapping to 1.9 stuff as not only are the disks and caliper pistons the same size there also heavier. Rich Share this post Link to post Share on other sites
