Peetypug
Rs2000 Mount
Peetypug
FP292%20Engine%20Mount.jpg is this it?
part number FP292? for a gti6 conversion
Edited by sorrentopete
philfingers
That's a MkII Escort Rs2000 mount, is that the one you want?
willxs
im selling one of these. it'll be up in the forsale section soon. £10 if your interested? brand new.
Peetypug
i've read that for the 6 conversion i will need an rs 2000 mount off burton power
this is the only one i can find on there
philfingers
A landrover mount is not quite so thick and is stiffer. Certainly the ones I had were- used to mount a engine in a westfield
give BakerBM a call I'm not sure if he has shorter mounts in production yet.
felix2566
Yes it is the corret mount!
tom_m
not so thick as in height between the treaded bits or in girth?
Peetypug
not meaning to sound like a tight git, but in that topic he says £30
the ford one is £8.50 and i'll need a few big washers.
so thats about £10 all in
i know which one i'm thinking of getting
jonnie205
be carefull, those mk2 mounts are different heights, when a pinto is mounted on an escort x member one mount is taller than the other, made this mistake a few times when working on my escort rally school cars
Spiky
i bought the 50mm one from burtons ;) and i put 2 washes on it, so there is a 1-2mm gap from the MC to the rocker cover of the engine :lol:
Edp
Same as spiky, although I have a bit more space between the m/c and cambelt cover which is curious.
Peetypug
well, i'm going to get it and i'm also going to put washers under the servo to tilt it slightly as well <_<
Spiky
i'm running a 406 MC
Peetypug
what about using the GTI6 m/c?
is that different to the GTI?
spikey thanks for earlier, the pc seams much faster now as well <_<
Spiky
you need a 23mm MC non PAS 406 one
glad about ya pc , less chance of me catching anything off you ..lol
Peetypug
off to the scrappy on monday then
and to think that i bought a new GTI m/c just before chrimbo <_<
that'll teach me to go spending my money before i decide what i'm doing
Spiky
<97 model
buy a new one, not worth the chance only 40quid
Peetypug
ta <_<
danpug
Theres one in willxs's thread in for sale.
gti_al
Is anyone got one of these mounts fitted? Are they a oem feel, or stiffer like a group n one? I have a solid lower top mount in mine now, and the vibrations are starting to piss me off... wouldn't mind a more standard feel, but need the clearance
Anyone got any ideas?
Guest Paulus205GTI
So you need a RS2000 top mount of a MK2 (model before 1997)?
I'm from The Netherlands. Do I understand it well?
Gr.Paul
Peetypug
i bought it but never used it
i've tilted mine, but you can use the standard mounts and modify the bulkhead
Guest Paulus205GTI
@sorrentopete: could you mail me a picture of the top mount you've boughted?
My e-mailadress is 'paulus205gti @ hotmail . com'
Thnx!
Gr.Paul
