djinuk 2 Posted March 27, 2008 I have a oil leak on my 205, (loosing quite a bit), and it appears to be everywhere, i cant see anything obvious like oil filter, leaking and there are no split pipes, is there a good chance it is my sump leaking, if so whats the best stuff to use, and how much of a job is it. Cheers Share this post Link to post Share on other sites
205007 12 Posted March 27, 2008 more likley to be dipstick, rear main or distributor oil seal best to rev it up with the bonnet open and get your talcum powder out you can buy sump gaskets from pug for £10 ish and they do the job pretty well Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted March 28, 2008 If its leaking at the front of the block have a good look at the low oil pressure stop lamp switch. A friends 205 was leaking oil quite rapidly & this was the problem. Oil was coming straight out of the end of the sender. Graham. Share this post Link to post Share on other sites
