davepug205 7 Posted March 24, 2008 Hi Well im in the prosess of removing the seamsealer from under the shell, Ive spent days with a heat gun and scraper but dont SEAM to be getting anywhere. Can anyone help there must be some sort of remover acid type thing out there somewhere. thanks dave Share this post Link to post Share on other sites
Peetypug 5 Posted March 24, 2008 have you tried a bit of elbow grease sorry , that doesnt help with your question does it? Share this post Link to post Share on other sites
davepug205 7 Posted March 24, 2008 have you tried a bit of elbow grease sorry , that doesnt help with your question does it? well if you dont mind lending me a bit Share this post Link to post Share on other sites
M@tt 77 Posted March 24, 2008 wire brush on an angle grinder is what i used Share this post Link to post Share on other sites
Pugnut 9 1 Cars Posted March 24, 2008 wire brush on an angle grinder is what i used me too Share this post Link to post Share on other sites
davepug205 7 Posted March 24, 2008 wire brush on an angle grinder is what i used Sorry Ive also done alot of that as well but thanks for the quick reply. The problem being i can only work on it after work at night. My garage is rented in a residential area, and Im only meant to use it for storage so i dont wont piss the neighbours off as we have all got the same landlord. Garages are very hard to find in this area if you now what i mean. Share this post Link to post Share on other sites
davemar 16 Posted March 24, 2008 I'm try to hack some of it off myself at the moment, as I'm replacing one of the rear bumper mountings. I've been slicing through the metal with an angle grinder cutting disk, and the heat generated off that seems to help free it up a bit (plus lots of smoke!). But I managed to lever a fair bit off once you get bit of metal exposed and you can get under it. Share this post Link to post Share on other sites
phonecomz 0 Posted March 25, 2008 Not sure what anyone thinks of this but im told my a friend in the us that it is "Thee tool"... hmmmm expensive though :-( http://dentfix.com/viewitem.asp?idproduct=95 No good for getting wings of on a pug i bet... might do the floors ok... burning seam sealer produces cyanide gas i believe iirc, that blue smoke aint all that good so make sure your well ventilated... I think wire brushes on drill/grinder and putty knife, patience, more patience, and that should do it eventually. Those twisted/knotted wire brushes seem to work well(more heavy duty). http://www.rightlines.ltd.uk/image.aspx?imgID=43 Or a cup type of the same twisted sort... Share this post Link to post Share on other sites
mickie 3 Posted March 26, 2008 (edited) nitromors does the job quite well, stick some on, scrape it off, then apply some more till it comes off.. its not very nice to work with but it does the job without power tools, but if you could get something like a generator buy one of those knotted wire brushes for an angle grinder, they're amazing and last for ages edit sorry i thought you had no electric Edited March 26, 2008 by mickie Share this post Link to post Share on other sites
