luggy 13 Posted March 23, 2008 Im at my wits end having refurbed the engine and box over the last 5 months now I cant get the bloody thing to start. It turns over fine and there is fuel but no spark. Timing has been double checked Plugs, leads, dizzy and rotor are new, tried a known good coil, CAS and Ignition amp. Lead locations double checked. Checked the earths, Ive had the link loom out, double checked it, took the main loom out to check for any damage but it came from a known good working donor which I broke. One thing I did break was the coil, which melted on the king lead side. Can this signify a problem? Only thing left to swap out is the ecu which Im currently in the process of buying, any other suggestions please fire away. Share this post Link to post Share on other sites
welshpug 1,666 Posted March 23, 2008 which management system is it? Share this post Link to post Share on other sites
luggy 13 Posted March 23, 2008 which management system is it? Motronic 1.4 with knock sensor, 3 row ecu. Share this post Link to post Share on other sites
nick 3 Posted March 23, 2008 Check the two relays on the Mi/bx loom, I think one does the fuel and the other does the sparks. They get dry joints on the boards inside, one of these caused me a right headache with an intermitent problem once. Nick Share this post Link to post Share on other sites
luggy 13 Posted March 23, 2008 Check the two relays on the Mi/bx loom, I think one does the fuel and the other does the sparks. They get dry joints on the boards inside, one of these caused me a right headache with an intermitent problem once. Nick Cheers, both relays are known good but Ill check to make sure the connections loom side arent corroded. Share this post Link to post Share on other sites
pee vee 1 Posted March 23, 2008 (edited) check crank sensor connections too mate. EDIT: or did you mean that by CAS? Edited March 23, 2008 by pee vee Share this post Link to post Share on other sites
luggy 13 Posted March 23, 2008 EDIT: or did you mean that by CAS? Yes mate, and the connection checked too. Share this post Link to post Share on other sites
Phil H 16 Posted March 24, 2008 Check the two relays on the Mi/bx loom, I think one does the fuel and the other does the sparks. They get dry joints on the boards inside, one of these caused me a right headache with an intermitent problem once. Nick Also check hat you have the two relays the right way round. Mine wouldn't start, so I swapped them around and sorted it. Share this post Link to post Share on other sites
luggy 13 Posted March 24, 2008 Also check hat you have the two relays the right way round. Mine wouldn't start, so I swapped them around and sorted it. Cheers, checked that made no difference. Opened up the ecu, some corrosion on the joints, cleaned up with WD40 and a toothbrush and no spark. Awaiting replacement ecu, will let you know the outcome. Share this post Link to post Share on other sites
luggy 13 Posted March 26, 2008 ECU replaced, still no spark at the coil! There was an alarm system on it but the only poer to the main box was a feed from the ignition and power to the flashing LED. It seems it was more for show and seems to have already been cut back its a Clifford concept 2. If anybody has any suggestions on anything it could be no matter how trivial I would much appreciate it Share this post Link to post Share on other sites
welshpug 1,666 Posted March 26, 2008 do you have power at the coil? Share this post Link to post Share on other sites
sutol 0 Posted March 26, 2008 I once had a similar problem with a standard 1.9 with an alarm. The earth that fits on to the front struts was disconnected after some work on the car. Don't ask why but after reconnection the car started Trivial enough ? Share this post Link to post Share on other sites
luggy 13 Posted March 26, 2008 At ignition on Ive checked pin 4+ and 3+ and there's 13.6v but at 2- and 1- I'm getting 1.3v. I'll be honest Im not bad with the mechanical stuff but when it comes to the electrical side of it I still have a lot to learn. Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted March 27, 2008 Three row ecu is M1.3 not 1.4. What car is your loom from? A simple one if its from a BX is have you earthed the single (brown) wire that comes out from the ignition amp plug with a ring terminal on the end? IIRC the 405 has this same earth wired into the main loom through one of the two loom plugs but still needs to be found & terminated at an earth point for you to get a spark. Graham. Share this post Link to post Share on other sites
luggy 13 Posted March 27, 2008 The mi is now running, knowing that the loom and other components were working good the only thing modified was the link loom. Had a look at it again today and noticed that on the 205 side of the link loom wire 112b and 112c for the rev counter was joined to 112 and the unshielded wire next to it on the Mi loom. The unshielded wire is the earth for the rev counter OOPs . Rectified it by joining 112band 112c together to 112 on the mi side and earth earthed. All I have to to now is sort out the fuelling on no 2 cylinder, cheers for the responses guys. Share this post Link to post Share on other sites
pugman211 0 Posted March 29, 2008 whats wrong with the fuelling on no.2????? Share this post Link to post Share on other sites
luggy 13 Posted March 29, 2008 whats wrong with the fuelling on no.2????? No 2 spark plugs' clean and dry, all other 3 are wet and sooty. Share this post Link to post Share on other sites
luggy 13 Posted April 2, 2008 Problem sorted, turns out it was the dodgy Ducilier Ign amp ,which worked fine on the 8v, replaced it with a bosch one and finally she runs smoothly! Share this post Link to post Share on other sites
luggy 13 Posted April 8, 2008 After a little tidying up in the engine bay again had issues with the Mi running on 2 cylinders. Checked the usual, turns out the AFM doesnt like sitting in the vertical position, reangled it at 45 deg, fired up ran a little lumpy for the first couple of mins but it sorted the problem out. Share this post Link to post Share on other sites
jackherer 543 Posted April 8, 2008 After a little tidying up in the engine bay again had issues with the Mi running on 2 cylinders. Checked the usual, turns out the AFM doesnt like sitting in the vertical position, reangled it at 45 deg, fired up ran a little lumpy for the first couple of mins but it sorted the problem out. That shouldn't be a problem, chances are your AFM is faulty. Share this post Link to post Share on other sites
luggy 13 Posted April 9, 2008 That shouldn't be a problem, chances are your AFM is faulty. Cheers, its about the only thing left to change/fix, seen a thread by Matt who's just refurbed his AFM after cam upgrade with piccys so I'll give that a go. Share this post Link to post Share on other sites
