Peetypug
Just About To Unplug My Ecu On The Gti6
Peetypug
right i'm just about to unplug it so just want to make sure that i do it right
is it turn the ignition on then unplug it or start it then unplug it?
i'm doing it in the next few mins
GTI6BOY
Peetypug
thanks for the reply
will it then stay unlocked for good?
i know its a silly question, i just dont want to mess it up then have to pay for it to be unlocked :)
if i was to plug it back in after would it stay unlocked?
you need it in position 2 to unlock it, as long as the ecu doesn't get a "lock" signal (from the transponder) it'll stay unlocked :)
Peetypug
wooo hooo
unplugged and safely in a box
James_R
easiest way to check is remove the key from the plipper, then after it's locked try firing the engine back up with the plipper no where near the ign barrell, then if its not unlocked you can try again at least.
Spiky
i told Dixon to remove the ecu while it was running,
it worked perfect and has been in my car ever since :)
Peetypug
well
i pulled the ecu and wiring clear of its box
turned the key 2 clicks so the ignition was fully on
then unplugged it
TurboSam
Its so much easier to do on a phase 1 keypad car, atleast you can check if it works straight away without any messing around.
Edited by TurboSam
taylorspug
well
then unplugged it
That will be fine. :lol:
Peetypug
i'm starting to get really excited!
just got to get a few bits in the bay done then its onto the easy task of the wiring :lol::o
Spiky
add me on msn or pm if you need a hand with the wiring :lol:
Edited by Spiky
Peetypug
cheers spikey
will add you when i get home :o
