16v205 9 Posted March 23, 2008 Hi Anyone know roughly the ignition curves of a 1.6 and 1.9 gti distributer or anywhere I could find them online? Degrees advance per 1000 revs would be great. Cheers Rich Share this post Link to post Share on other sites
DamirGTI 342 Posted March 23, 2008 No , been looking for the same info in the past and found - nothing ... just the usual static/dynamic degree value and nothing listed regarding the entire rev range .. Rgs ! Damir Share this post Link to post Share on other sites
RossD 44 Posted March 24, 2008 (edited) If anyone has the French RTAI manuals, they have this info in. The french version of Haynes but 1000x times better!! This topic: French Forum - Scroll down for curves has a couple, the curve code (CO19 in this case) should be stamped on the dizzy somewhere. 'A' is the centrifugal advance and 'B' is the vacuum advance Also This topic - again at the bottom has the 1.6 and 1.9 curves superimposed on each other so you can see the difference. The blue line is the 1.9 and the red the 1.6. HTH Edited March 24, 2008 by RossD Share this post Link to post Share on other sites
16v205 9 Posted March 24, 2008 (edited) Thats great RossD, thank you very much. Rich Edited March 24, 2008 by 16v205 Share this post Link to post Share on other sites
Mad Professor 7 Posted March 24, 2008 Bosch (0 237 009 066) Share this post Link to post Share on other sites
