GTI6BOY
Jenvey Bodies May Need Refurb?
Plugs/leads/coilpack etc all three years old?
Obviously there is a problem somewhere, you are unlikely to solve it by guessing, so your other option is to datalog fuelling when it is stuttering and find out what is happening.
kyepan
took a vid earlier...turn the sound up and you can here my problem
also only does it when the engine gets up to temp
Might be worth getting the multimeter out and following the caps program guide thing on the xu board sticky to check the water temperature sensor, as that could cause it to overfuel on low throttle when warm..
My pulsar did the same thing when i put on a dump valve that was leaking.. exactly as you've got, neutral throttle... ug ug... purrrrrrr ug ug... so as previously mentioned could be an air leak too. where you might get that on a throttle body inlet with no AFM i'm not sure though.
base-1
He said it done it before it went to longmans also but not as frequent. Howcome longmans never touched the fuel map?
Done what, changed all the water, air etc sensors? No mention of that....
Check everything is properly dry. If Longmans balanced the bodies OK then it's pretty unlikely that they will be wrong on only marginal throttle but fine at idle/half - full throttle. Did you only cover the bellmouth with gloves?
Edited by base-1
GTI6BOY
by one of the bodies having wear in it...this is what ive been told the problems is likley to be
base-1 - year its fine on idle and its fine over 50mph
i just covered the trumpets yes
base-1
Or by the manifold not being sealed against the head perfectly, or the bodies not being sealed against the manifold perfectly, or one of the fuel injectors not being sealed into the bodies perfectly
Also check the injectors and any other plugs you didn't cover to make sure there's no water trapped in there
GTI6BOY
Checked all that!
Ive taken two more better vids...the first one is the bodies flaming, while driving everytime it does it the car pulls back
The second vid is so you can here what is happening through the exhaust, this is being held on about 2k rpm
gonna try and get the car back to longmans in the week
taylorspug
Timing looks miles out to me...
Is the crank pulley original?
GTI6BOY
no its a rich w special
taylorspug
Either the ignition is running too much advance or the cams arent dialled in correctly in order for it to be spitting back out of the 'bodies like that.
j_turnell
i'd get your ignition and cam timing checked if i was you.
James_m
At least you can say the bodies are ok, as its happening on all of them by the look of it. Id expect Longman of all people to be able to give you some decent advice on what the problem is.....
GTI6BOY
cant be the timing can it as i had cambelt done two days before and it was driving fine
taylorspug
It is definately timing related. After seeing that video there is nothing else it can be. Send that video link to Longmans, they will say the same.
GTI6BOY
would they have touched the timing or is it a manual thing?
taylorspug
Cam timing may have been done wrong when the belt was fitted, ignition timing is part of the engine map. What did you say Longmans hadnt touched when they mapped it? Is it on std cams?
It looks like cam timing, as in the first video you can see what looks like air/fuel mix being purged back out of the 'bodies unlit (before the flames start), which would suggest the cylinder is coming up on the compression stroke with the inlet valve still slightly open, pumping the air/fuel out.
Id get the belt cover back off and check the cam timing hasnt slipped or been done wrong when the belt was changed.
GTI6BOY
has uprated cams
longmans use a base map first which is used on all gti-6 throttle bodied cars then they live tweek it on the road.
did not start to notice problems till about two days after mapping and cambelt was done about 5 days before mapping and was defo running sweet as for those 5 days
going to longmans friday
GTI6BOY
All fixed now and its running sweet as a nut :)
There was a problem with the map at 2800 rpm
I also now have launch control fitted and it sounds unreal
:) you're gonna have to do a vid of that!! Edited by welshpug
j_turnell
Yeh a vid on full chat would be nice :)
Bonzai
how does launch control work? i seem to recall needing the abs hubs to use traction control, is it similar to that?
GTI6BOY
Max torque on my car is 5600, an extra rev limit is set to 5200 while holding button. Foot flat on the floor, release button and you launch at max torque!
Sounds awsome
Dream Weaver
Glad its sorted, I think you need to sack whoever said it was a worn throttle body :)
You would do well to read a few books about engine management even if you don't plan on doing any mapping yourself - I'm no expert, but its amazing what you can learn about fueling/timing from reading a few books/websites.
GTI6BOY
right...
has been running sweet for the last week but has now started to do the same thing???
My little knowledge i know on mapping, i was under the impression that the map cant change unless its put on a laptop?
Bonzai
i would say if somethings changed its almost certainly component failure of some description
