danpug
Quick Torsion Bar Question
danpug
Are 205 1.6 and 1.9 torsion bars exactly the same? I'm pretty sure they are but just need to check. Thanks.
sutol
I've measured a 1.6 and a 1.9 and also a 205 TD and all the front ones are the same thickness so I presume that they are all the same. :P
pip470
I've measured a 1.6 and a 1.9 and also a 205 TD and all the front ones are the same thickness so I presume that they are all the same. :(
What size did you get for a standard torsion bar. Cheers Phill
Standard are 19mm IIRC.
AdamP
What are the lower model ones (XS etc)? Are they skinnier?
Jrod
Yep they are smaller, cant remember if it's 17or 18mm though.
18mm for lower spec models afaik.
Even my STDT had an XS spec rear beam on when I stripped it, not anymore though. :(
Graham.
RossD
Base models are 18.1mm with 14mm anti-roll bar
XS/GT models are 18.5mm with 16mm anti roll bar
GTi models are 18.9mm with 19mm anti roll bar
