m_pugz_1986 0 Posted March 21, 2008 i have a 1993 k plate 1.9 , it has motronic management on it , i changed the engine for a earlier non cat model and i noticed the flywheels where different as the motronic fires off the crank possition sensor ? am i right ? as i assume by having teeth on the outer ring of flywheel . i was wondering is this the same flywheel as the mi16's as have ? I seen a few projects on here and look close to the mi flywheels Share this post Link to post Share on other sites
jackherer 543 Posted March 21, 2008 The Mi16 flywheel uses a 215mm clutch but both Motronic and Jetronic 8V flywheels use a 200mm clutch. Share this post Link to post Share on other sites
m_pugz_1986 0 Posted March 21, 2008 The Mi16 flywheel uses a 215mm clutch but both Motronic and Jetronic 8V flywheels use a 200mm clutch. i know that but it looks same as a mi flywheel , just wondering if was the same as a mi or looks the same Share this post Link to post Share on other sites
jackherer 543 Posted March 21, 2008 You've answered that yourself really, its the same in that it has a 60-2 arrangement of timing gear teeth for the crank sensor but its different in that it takes a smaller 200mm clutch. Share this post Link to post Share on other sites
m_pugz_1986 0 Posted March 21, 2008 You've answered that yourself really, its the same in that it has a 60-2 arrangement of timing gear teeth for the crank sensor but its different in that it takes a smaller 200mm clutch. ah i see how hard is it to come by these flywheels ? Share this post Link to post Share on other sites
jackherer 543 Posted March 21, 2008 The 200mm 8v motronic flywheels are relatively rare but the 215mm flywheels are very easily available. Share this post Link to post Share on other sites
