sutol 0 Posted March 20, 2008 Found these under some parts in garage, any one recognise them ? Part Nos on box ........2050 W7....................................................................2057 42............... Could do with a good home Share this post Link to post Share on other sites
welshpug 1,657 Posted March 20, 2008 from what I can find 2050W7 is a 200 mm tu clutch 2057 42 isn't recognized by the system at all though! Share this post Link to post Share on other sites
sutol 0 Posted March 20, 2008 from what I can find 2050W7 is a 200 mm tu clutch 2057 42 isn't recognized by the system at all though! Thanks, the 200mm one has a smaller pressure plate than the 205 and the other one has a larger pressure plate than the 205 so if one is TU then I suspect that the big may be the wrong number (me ). I might keep the plates as the big one has bigger springs than 205, I'll check if they fit the box. Share this post Link to post Share on other sites
sutol 0 Posted March 20, 2008 The big one has a 230mm plate. Share this post Link to post Share on other sites
welshpug 1,657 Posted March 20, 2008 oh, ummm! could you double check the part number? that's a ruddy big clutch for a pug! Share this post Link to post Share on other sites
sutol 0 Posted March 20, 2008 oh, ummm! could you double check the part number? that's a ruddy big clutch for a pug! Checked it and it's in a pug/citrn box. The release bearing is different to a 205, no wings. Could be in wrong box but it has the blue centralising tool same as the other one and the splines look the same but could be ever so slightly different but hard to tell. It is a big clutch though, maybe V6 or later diesel.?? Share this post Link to post Share on other sites
