Flix
Quick Fuel Pump Question
Flix
Hi
I removed my fuel tank on my 1.9 GTI to fit a rollcage.I cut the original hoses off the fuel pump as I'm going to replace them with new ones.
Now I've refitted the tank and can't remember which one is which. Knew I should have marked them. :blush:
Can anyone tell me which one is the outlet.
Thanks in advance.
Pugnut
Hi
Thanks in advance.
blow back down the pipes . the supply has a non return valve . the return will be free to blow back into the tank
Flix
Great idea, thanks for that.
Flix
Worked a treat the rear pipe is the outlet. ;)
